Thread: Autopilot High Salt Reading
    Dig-220
    I had my water tested a few times and it is at 3200ppm. The Autopilot says it is at 6800ppm. I tried to reset the calibration but it stays at 6800ppm. I removed the Tri-Sensor and all is clean. I checked the cable and there is continuity and no shorts. Any Ideas?
    Thank you for reading
    Re: Autopilot High Salt Reading
    Welcome to TFP!
    What did you use to measure the salt level? Many of the common salt tests are not at all reliable, though a few of them are alright.
    If the AutoPilot is really off by that much, there is no way to adjust it that far, calibration is limited to something like +-1000.
    I had the local pool store test it. I am sure they are not off by that much.
    22,537
    Did you have the same store check it each time? If so, I'd take a sample to a couple different stores. The first one may have test issues.
