Thread: Sodium Hypo 1.5g per 100g
    jay87's Avatar
    May 2011
    Gloucester, UK
    16
    Hi All
    I have just opened my hot tub for the season . Am using the dichlor then bleach method so finished with the dichlor, now on to the bleach.
    I'm in the UK. a value brand of bleach says less than 5% Sodium Hypo, but also 1.5g per 100g. Does this mean anything? Any indicator of strength?
    Thanks
    Softub T300 resort 1135l hot tub with ozonator using dichlor then bleach method.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Sodium Hypo 1.5g per 100g
    There was a time, way back when I was taking chemistry classes, when I would've been able to figure out molecular weights and so on and figure that out. But that was too long ago.
    It's definitely not straight arithmetic, it's not 15%. My guess, being a discount brand, is that it's somewhere around 3%.
    If EU regulations make finding stronger household bleach impossible, there is the same thing -but stronger - sold for sterilizing dairy equipment. A little online searching turned up 10% and 11.8% Here's just one of the links. If there's a farm supply store nearby, it would certainly be worthwhile to check pricing and availability.
    If 1.5g per 100g is by weight, then it is 1.5%.
    jay87's Avatar
    May 2011
    Gloucester, UK
    16
    Hmm. Lucky its not a pool then! Its only 23p (35 cents) for 2 litres so I'm not that fussed. Will just use 2% on the pool calc then
    Thanks Jason and Richard. I'll look into dairy bleach
