Thread: Maytronics Dolphin Sprite
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Hi Guys,
    Just picked up a Dolphin Sprite as my last robot died and out of warranty.
    I only have one issue, when the robot finds it's way to the main drain cover the robot gets hung up (beached) and I have to pull it off manually.
    Any ideas how to resolve this one?
    thx
    Steve-Liteguy
    13K Pebble-tech Pool, ECO pump, IntelliChlor SWG, DE
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Re: Maytronics Dolphin Sprite
    http://stores.maindrainclipon.com/-strs ... gories.bok
    after further searching, i found these clips which i will try out.
    Steve-Liteguy
    tcat's Avatar
    May 2012
    Austin, TX
    731
    How are you liking the Sprite? I'm torn between buying it (which is essentially a DX4), or an Aquabot XLS. I currently have a Legend Platinum (5 years old), only climbs walls about 12". Does a good job, but I leave it in the pool 24/7 for it's 2 hour cycle each day. I'd rather have something I can use "as needed", that cleans walls and tile line, and doesn't require the extra pump. A robot looks like the answer.
    Quote Originally Posted by Liteguy
    Hi Guys,
    thx
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    mtheaded's Avatar
    Oct 2007
    Lovettsville, VA
    46
    I just got the Dolphin Sprite Plus ($699 from Backyard Pool) and I've only used it once but I like it much better then the Blue Pearl it replaced. Clearly better designed and it seems sturdier than the Blue Pearl. It came with a caddy which is pretty flimsy but still handy for storage of the unit. Only time will tell, of course, but it did a great job of cleaning on it's first time out. Probably going to run for the second time today!
    26,000 gallon IG Vinyl Lined, Hayward DE2400 Filter, Hayward SP2610X15 1/2 HP pump, Dolphin Sprite robot, open May to October
