Winter deck replacement to composite, adding fireplace
Apr 8, 2011
79
Here are some pictures of my deck rebuild. I removed a 20+ year old deck and started over from scratch. Wish I'd taken a few more pictures. I started the fireplace before demoing the old deck. This was easiest for me to know it was in the right spot. Original deck was 16x16, I went with 16x18 to clear a window. Finished product has screened walls but an open canopy roof shade.
If I remember correctly there are 13 posts now, all about 3' deep. Before we finished the framing a trenched a gray water french drain from the kids bathtub to help my trees. 2 kids a bath a night, 300 gallons a week I was giving back to city! After framing but before decking I put down 12x 3cuft bags o aromatic cedar under the deck for our dogs' favorite spot. I plumbed natural gas to my BBQ and my fireplace. For the fireplace I made a log lighter from 1/2" gas pipe with 4x 1/8" orifices drilled. It can be turned up to a roaring fire, but the heat really goes right up the chimney. Reclaimed/ used materials, my glass panels are old shower stall doors, 2 were on the original deck, 3rd came across tearing down another house. Fireplace liner, curtain, log rack, gas valve I lucked out finding on another teardown.
The benefit of going with 16' width was being able to use full 16' boards with zero waste. Maybe not the best Idea but I did this project with out blueprints or drawings, mostly because I've been planing this in my head for a long time. I went with french doors to the stairs, I wanted big stairs, and a good sized opening I can close. I thought I could buy 30" screen doors of the shelf but alas, less than 32" is special order, adding $100 per $30 door. Instead I built my own from treated decking. Way stronger than your average screen door.
