Thread: Quanity of bleach
    Quanity of bleach
    New here . How much bleach would you use for a 18X33 oval pool to shock it. I used 1 1/2 pound of shock. I have cloudy pool with all readings good.
    thx Mike
    Hydomatic Pressure cartridge Filter
    Prc120 HP 3/4
    18x33 oval above ground pool vinyl 19,600
    Butterfly's Avatar
    South Carolina
    Welcome to the forum
    Post a full set of water test numbers! Then, help will be on the way!
    You're done SLAMing when:
    Pool numbers
    Here are the no.s from leslies
    Fac 4.0
    ph 7.4
    ta 130
    cal hardness 220
    cya 60
    tds 1000
    Prc120 HP 3/4
    With CYA of 60, shock level of FC is 18. A an 18x33 that averages 5 feet deep is about 19,600 gallons. To raise FC from 4 to 18 in 19,600 gallons will take 4 1/2 gallons of 6% bleach. If your average depth is not 5 feet you will need to adjust that.
    You can use my pool calculator, see the link in my signature, to figure out things like this.
    Remember that shocking means testing the FC level, adding enough chlorine to bring FC up from there to shock level, waiting a while for the chlorine to work and then repeating the process frequently, up to once per hour, until FC holds steady overnight.
