Thread: Sta Rite Heater problem
    I can press pool on button and the heater will turn on and heat to the thermostats setting and then turn off as it should. The problem is sometimes it doesn't turn back on and the service heater light is on. This happens randomly. Sometimes it will run fine for 1 day, sometimes 3-4 days before i notice it has stopped working. There are no led code lights illuminated on the back of the board and there are no error codes. I've tried to turn the thermostat up and down to cycle it on and off to see if it will act up with me there, but without any luck. I was hoping to see if the service heater light came on when it shut off or when it tried to restart. Anyone have any ideas? It's a 333K btu Sta Rite Max-e-therm.
    Thanks, Matt.
    38,415
    Re: Sta Rite Heater problem
    Welcome to TFP!!!
    Sorry you have not gotten a response about your heater yet. Hopefully someone will have some thoughts after this is bumped back to the top.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Since you can't easily reproduce this it isn't going to be easy. You're going to need to a volt meter to start checking things when the heater acts up. You're going to have to check all of the safeties and you might find it, hopefully. It could just be the control board but without purchasing a new one you won't be able to swap it out to see. It could also be the module in that it's communicating correctly. Again, this type of problem is not easy to track down. Its trial and error.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
