Results 1 to 8 of 8
Thread: Glass Pack Filter Media
    Mar 2012
    Lewisville, Texas
    71
    http://www.ecosmarte.com/
    I noticed on the page with filter comparisons that Glass Pack filter media isn't mentioned. It appears they work similar to sand filters, but with better filtration because of smaller particles. I've read various problems with the Ecosmarte system in regards to sanitation, and people saying its harder to balance pool chemicals with it.
    Are the Glass Pack Filters also not any good? Anyone have any experience using one? The filter comparisons page did an good job of explaining differences in sand, DE, and cartridge but I'm still not sure which I should go with.
    I'm thinking we will probably want to either get a new cartridge filter or change filters soon, but I'm still not sure what the best one would be.
    http://www.glasspackfilter.com/?view=benefits
    http://www.glasspackfilter.com/?view=filters
    The benefits page sounds good, but considering its from the company selling I'm trying to research it to make sure its a good idea.
    Lewisville, Texas 22,000 Gallon IG Plaster Chlorine FNS Plus Vertical Grid D.E. Filter 60 sq. ft. 150 GPM Push/Pull Valve Hayward Ecostar SP3400VSP Baracuda Zodiac G3 Cleaner
    Caldera Vacanza Marino Vanto Spa VMA4R6393
    Re: Glass Pack Filter Media
    We recommend using sand. It is well understood, inexpensive, eco friendly, and reliable. Glass filters are too young and haven't really proven themselves yet. I've heard some good things and a couple of horror stories, and would rather let the technology settle out for a while and see if the problems were early technology problems or fundamental to the design.
    Which of the three common kinds of filter to use is mostly a personal preference. All three work very well for many people.
    Mar 2012
    Lewisville, Texas
    71
    Thanks for the response that was fast. I read the Glass Pack media can actually be used in most sand filters so I suppose I could get a sand filter and switch to Glass Pack later if I feel its a good idea. Could you direct me to the horror stories or were none of them Internet postings. I'm curious what the problems are.
    On an unrelated note I'd like to know if my plan of action is good on getting my pool water clear. I just used Natural Chemistry's pool first aid and than realized I should probably fix the pool chemistry first. So what I should do is add CYA to 30 ppm since its at 0 add Chlorine because its at 0 and than adjust ph down because its at 8 something. After all of that I should try the First Aid again. I don't know why I didn't think to fix the chemicals before using the first aid.....
    Does that sound like the right plan?
    Also I recently cleaned my filter, but stopped before the water was completely clear. I guess that means it wasn't completely cleaned...I used the hose around the entire cartridge for several minutes, but it never became completely clear. I suppose with a cartridge I'm reducing efficiency if I don't wait till its completely clear to put the cartridges back into the filter.
    One more thing...keep on coming up with questions ... lol My pool filter's pressure guage is reading at much less than 10 and I think my mom said that it was supposed to be at 10 when running...but I'm not sure if that was at speed setting 3 on the pump or what. Whats the best way to determine if things are running like they should? Speed setting 3 is 2500 RPM. Its a 22000 gallon pool.
    Feb 2011
    2
    Glass as a filter media is a well established and proven technology. Glass is a common filter media in Europe and Australia, and is gaining acceptance in the United States, especially on the West Coast. Yes, I'm biased because I sell Vitroclean, the only glass filter media in the US that is performance tested to NSF Standard 50. We've been manufacturing Vitroclean for over 15 years and have thousands of pools that use Vitroclean. --- Jeff
    Mar 2012
    Lewisville, Texas
    71
    Quote Originally Posted by VitroClean
    What's the difference between Glass Pack and VitroClean. Is it something besides being tested to NSF Standard 50 whatever that is?
    I'll go look that up because I don't have any clue what that is.
    Feb 2011
    2
    Most states require NSF Standard 50 certification for filter media to be used in a commercial application. Passing the performance tests for NSF Standard 50 means that NSF certifies that the media actually works and is non-hazardous.
    Eco-smarte's media is coarser and does not meet the NSF performance standards.
    May 2013
    North East Ohio
    959
    Run away from anything from ECOSmarte - especially the Glass sand media, don't ask me why.....
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Apr 2013
    North OKC Area
    300
    CYA doesn't really show up until around 20ppm. If you had CYA in the pool before, only add enough to increase it 20ppm to start off. If it is a completely fresh fill, go ahead and add enough for 30 to 40 ppm. Your PSI will vary by pool, ask your mom what speed setting 10 PSI is normal for. If your pool is crystal clear, your chemicals are balanced, you're not losing more than 1ppm chlorine overnight, DE isn't dumping in the pool, your filter PSI and return flow is normal for the speed setting you're on, and you don't have a lot of air in your pump basket causing it to shoot out your return jets, then it's pretty safe to say everything is running like it should.
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
