Thread: Very localized scale - - Why and how to remove?
    Jan 2010
    Northern Virginia
    282
    I just opened my pool and for the most part it looked great but I had some very localized patches of scale. There were 3 or 4 places around the pool where "lines" if scale have formed. They are all very similar to the attached photo - between two tiles near the surface. Last year I only had one, but this year there are a few more.
    Does anyone know why this is happening in these spots and how I should remove them? Is there a way to prevent more from forming next year?
    Thanks!
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: Very localized scale - - Why and how to remove?
    It looks like effervescence. Check out some of the pictures in this thread: what-is-this-white-stuff-t34141.html
    Jan 2010
    Northern Virginia
    282
    Hummmm. It might be, but I'm not sure. The photo in the link looks like it's a stain rather than a growth. Mine are "three dimensional".
    The other difference is my pool is surrounded by concrete decking (not backed up to a dirt hill like in the photo) so I wonder how much rain water could actually seem in?
    30,423
    Pretty sure that is efflorescence wherein minerals migrate from behind the surface of the tile and grout onto the surface.
    All you can do is clean it with muriatic acid until it stops......which can be a long time.
    It's pretty common for water to be behind the stain (other side of the pool wall) as that dissolves the minerals and then allows them to migrate forward.
    Jan 2010
    Northern Virginia
    282
    Thank's for the second opinion!
    Another contributing factor may be that I haven't had the area between the coping and the deck sealed yet. I'm planning to do it this fall, but right now, it's pretty much an open gap.
    30,423
    Good point. That certainly could be a contributor.
