Thread: One solution to high CH
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Well, my CH is approaching 900 again. Warm temperatures and a lot of wind recently have evaporated it down. The weather forecast shows 20% chance of rain, at best, 8 days from now. I think I can rule out rainwater dilution for a while.
    So, it's time for a partial drain and refill.
    I noticed the kitchen drain was a little slow when I was using the disposal a few weeks ago, and a few months back we had to have the main line snaked out, so....
    I pulled the cleanout plug behind the kitchen sink - the farthest point from the main drain line. I have a submersible pump flushing out my sewers now with pool water.A few thousand gallons ought to clean things out, don't you think?
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: One solution to high CH
    you would hope so .
    I used your past example of rain water dilution myself this year and have had 14" of rain which really help bring CH down over the winter.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
