Thread: DIY Umbrella Sleeves
    Hello fellow TFP enthusiasts! I'd like to have several umbrella sleeves in the concrete decking around my pool. I've found a few on-line but I'd love to make them myself because time is a factor. The pool is finished and the pb is building the retaining wall and will be putting the concrete in soon and I'm afraid if I order them they won't be here in time.
    I read a thread on here recently but I cannot find it again...The poster had used a length of 1 1/2" pvc pipe for the sleeve and had even found a flush cap to seal it off when not being used. I'd LOVE to find out where those were purchased.
    Any ideas would be greatly appreciated
    26 x 37 x 8 Tee Shaped Pool / Mayan Liner w/ Sandstone colored bottom[/color]
    Hayward Max Flo vs pump
    SwimClear Hayward C3030 Cartridge Filter
    Aqua Logic 15T Salt Generator
    2 Hayward Universal Color Logic Lights (12 volt transformer)
    12 Volt Dolphin M-4 Cleaner
    6 Foot Diving Board
    Apr 2012
    Mason, Ohio
    119
    Re: DIY Umbrella Sleeves
    Quote Originally Posted by myoung36
    For my umbrella, my PB used the same type of brass cup that he used for the ladder and hand-rails. I can then secure a short length of PVC in the cup, and insert the umbrella in the PVC. I would guess that your PB should be familiar with this and should have extra brass cups available.
    34K gal IG, 37'x40' lagoon, vinyl, Pentair IntelliFlo VS Pump, 500# Hayward sand filter, Jandy SWG, Raypac heat pump, 4 deck jets, Hayward Super Pump + deck fountain, Dolphin Oasis Z5
    JimboAZ's Avatar
    Oct 2012
    Maricopa, AZ
    103
    txsteel posted this in another thread: new-build-in-metro-st-louis-t56262-20.html#p472958
    On the umbrella holders, you can make 6 of your own out of PVC for less than $4 each. 1 1/2" end caps $0.97,
    1 1/2" female adaptor $1.11, 1 1/2" x 2' PVC $3.12, and cap $0.20. Add in PVC cement it is still under $5. Plus no shipping, just $2 worth of tax.. Ask the PB or plummer if they will make you some. Our PB supplied ours.
    --22k gallon pool/spa, IG, pebble w/ glass beads/abalone, all tile spa w/ stacked stone and spillway, 30 sf waterfall, 3 telescopic fountains, EZ Touch 8
    --Pentair VS3050, Whisperflo waterfall pump, Clean & Clear 520 cartridge filter, Intellibrite 5G LED lights, Ozone, Q360 in-floor cleaning, 400k btu heater
    --100 perim ft pool, 25 perim ft spa, Depth 3.5' to 7', 405 sq ft travertine decking, TF100 test kit
    --Time Lapse Video of our Pool Build ---- Our Pool Build Thread
