Thread: Adding a spill over spa?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Has anyone here added a spill over spa to an existing in ground pool as a stand alone project and not part of a major pool renovation? I am thinking of something like an above ground spa area with spillover waterfall going into the corner of an existing in ground pool.
    Ike
    Re: Adding a spill over spa?
    We have had one or two posts from people who have done this over the years, none recently. The only real issue is structural, making sure the spa has enough support without putting too much weight on the pool wall, which probably wasn't designed to take any extra load. Aside from the structural issue, the whole process is fairly simple.
