Thread: adding chemicals together
    Will I run into problems if I add about 4 lbs. of sanitizer and 8 lbs. of borax at the same time?
    Which sanitizer? I assume you mean chlorine in one of its granular forms. If you can be more specific we can help you much better.
    If you mean some form of chlorine and adding one after the other then that should be fine. I wouldn't add them at the exact same moment.
