Thread: Turkey Baster?
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Turkey Baster?
    Does anyone use something like this to pull pool water to add to test vial? I hate getting my arm wet, then dripping on everything (like the blue scoop). I think I may buy something like that and add a hose to get down to 24" without getting wet. Would also be easier to fill vial to exact line. Just curious if anyone does this.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Turkey Baster?
    I just use a 4' length of 1/2" PVC pipe as a pipette. Your hands would have to be pretty small for your thumb to not be able to cap it. It cost less than a buck.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Turkey Baster?
    Best tool I ever heard of was a 3' scrap of 1.5" PVC. Drop it to 18" below the surface, put your hand on top to create the siphon (or is it vacuum?), pull it out of the water and hold it over the test canister, take your hand off, and viola! Test water from 18" down and your hands never get wet.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Re: Turkey Baster?
    Wow!, 1.5" seem real big. Like the suggestion, hadn't thought of that. I have a bunch of .5" I'll use next time.
    DIY chlorine feed
    BBB
