Results 1 to 20 of 20
Thread: A unique idea? (Dane's pool thermometer)
    DaneCE's Avatar
    Jul 2011
    VA
    279
    After my Acurite digital thermometer stopped working I looked for a decent replacement but that doesn't seem to exist. I looked at the standard floating Alcohol thermometer types but many reviews warned of low quality overall or problems with buoyancy (floating on its side).
    How about a giant meat thermometer tweaked to float?
    I bought the "CDN IRXL220 ProAccurate Insta-Read NSF Large Dial Professional" model from Amazon for $9.
    The only tweak that was done to make it float was to attach a round piece of foam under the dial. At this point it's been floating in my pool for 6 weeks and no leaks. I did seal the calibration nut with silicone just to be sure and this also keeps the foam from coming loose.
    I like that this thermometer can be read without removing it from the water. Mine tested to be pretty much dead accurate so no change was needed.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    Re: A unique idea? (Dane's pool thermometer)
    Here it is floating in my pool.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Back in the good old days Kodak made a dial thermometer for dark room use that read from about freezing to 140 degrees.
    38,305
    I have one of these ... which is pretty similar, but sits in the skimmer:
    Ridiculously overpriced for what they are.
    Feb 2011
    Petaluma, Ca
    665
    That looks good, I don't think you can buy a "good" pool thermometer, they are all cheap xxxx. If there was one that was graduated from 50 deg to 100 deg the resolution would be better.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Made my own skimmer thermometer
    Same idea as the Jandy one I saw for sale. I found this industrial stainless temp probe on ebay, 5" dial, 120f max with a 12" probe. After shipping I think I paid less than $30 for it. I did need to drill a tiny hole in my skimmer basket b/c its a tad too long. Large dial, easy to read, really hope it holds up. I like the idea of measuring the return temp because this should give you a better average reading.
    When the only tool you have is a hammer everything starts looking like a nail.
    Doughboy 16x24 "Aboveground Inground" in progress...
    DaneCE's Avatar
    Jul 2011
    VA
    279
    That 5" dial looks huge. I like.
    Those "inside the skimmer lid" ideas can't work for me because my deck covers the lid.
    Nov 2011
    Magnolia Texas
    80
    Great idea, thanks.
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    May 2011
    Bensalem PA (Philly Suburbs)
    82
    Now that looks inventive... I am needing a new pool thermometer since mine was giving me wildly varying readings at the end of last year that I didn't believe at all. Will have to try this out.
    18' x 38' x 52" oval AGP with 6' deep end (foam on the walls, preformed coving, and Happy Bottom floor padding)
    Pentair Optiflow 1 HP 2 Speed pump
    Pentair cc200 cartridge filter
    Pentair UltraTemp Model 110 BLK 108,000 BTU Heat Pump
    2 Intex SWG's (copper unplugged)
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Great ideas!
    DaneCE's Avatar
    Jul 2011
    VA
    279
    I was looking at something I received in the mail from PoolSuppliesdotkom and noticed my idea has been stolen. Has been stolen!
    http://www.poolsupplies.com/product/acc ... hermometer
    Hey, I think it's cheaper..oh yeah, shipping. See, mine's a better deal.
    Jun 2007
    New Jersey
    653
    For several decades, I have used an old-fashioned stainless steel Taylor on an insulated wire so that no copper is exposed to the water. It came with a rope but they rot away. I always have it about five or six feet down. Why would you take the temp at the top? That's usually several degrees warmer than most of the water in the pool.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by Durk
    Since my pool is drawing from both the skimmer and main drain there is no temp difference from top to bottom unless it is less than the 1 degree resolution of my temp sensor. I can draw from either the skimmer or the main drain and the temp is always the same.
    Jun 2007
    New Jersey
    653
    Quote Originally Posted by bobby1017
    You must run your pump a lot. I do fine with two 4-hour blocks. I definitely get a temp gradient on a hot sunny day, and a small one on a cloudy day due to convection.
    DaneCE's Avatar
    Jul 2011
    VA
    279
    yeah, when I'm in the pool my pump is on. I never notice a difference in temp from the bottom to top...although I have only 4 feet of water. I have serious circulation going on...if I'm floating I might get caught in a giant whirlpool.
    Feb 2008
    Denton, TX
    5,061
    The level of innovation that I continue to see on this forum throughout the years continues to amaze me.
    Feb 2011
    Petaluma, Ca
    665
    Right now it is on from 9 am to 6 pm.
    Jan 2012
    'burbs of Augusta, Georgia
    7,359
    When I leave my cover on till late afternoon then open it up, my top foot of water can be almost spa like with the remaining lower water refreshingly cool! Its quite remarkable, but i've never tested the differing temps. Once we get in and move it all about it becomes balanced. I think I'll get two thermometers and rig it up for curiosity sake.
    I just make my kids get in the pool to check the temp. Actually, I like it. I have a controller that reads temp but having something floating in the pool is nice. They have tons of options for grilling that are wireless, maybe one of those could be adapted?
    DIY 28x38x18 Full L, 26,000 gallons, Pentair VS Pump, SWG, CCP 420 Filter, Sta-Rite Max-E-Therm SR400HD Heater, EasyTouch Controller
  20. Back To Top    #20
    An interesting idea I saw today while doing research for some work stuff. Crestron makes a thermometer thats designed to be planted in concrete as you pour it. Might be a very cool option if you're building a pool.
    Crestron is insanely expensive but I'll bet you could do a bit of research and come up with something that works nicely with an arduino.
    14,000 gallon IG plaster pool, Cartridge Filter
