Results 1 to 7 of 7
Thread: Before and after iron stain removal
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Just thought I'd show what my pool looked like before and after treatment with Ascorbic acid treatment. The results are pretty amazing to me. Here are the before pictures.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: Before and after iron stain removal
    Here are the after pictures
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Amazing results. I have a feeling a bunch of folks are going to tackle this treatment now.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    I read though the write up on doing the acid cleaning and one thing it said was that the filter should be in recirculate mode to bypass the filter while cleaning. It said that flowing though the filter could cause problems. So I followed instructions and put the filter in recirc mode. However, I also wanted to rid the filter of any iron that could get back to the pool. So my solution was to put the filter in backwash and allow it to flow until the backwash water was completely clear. Then with the pump running and the filter in backwash I added 1/4 cup of AA to the skimmer, counted to 10 and shut the pump off. After 1 hour I just jogged the pump by turning it on for 2 seconds then off again. After 2 hours I repeated the jogging. At three hours I turned the pump on and watched the backwash water coming out. It was clear for several seconds then turned tea colored, then blood red. It ran blood red for several seconds, then tea colored, then cleared up.
    That was an eye opener for me so I repeated the whole sequence. The second time I didn't see any discolored water after soaking the filter for three hours.
    todd.scallions's Avatar
    Apr 2010
    Bartlett, TN
    57
    Man, it should look A LOT better than those after pics you posted. I can still see stains all over the deep end in your after shot. How much AA did you use?
    1.) 27,000 gallons
    2.) Sand Filter
    3.) In-ground
    4.) Vinyl Liner
    5.) 1HP/63GPM
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Quote Originally Posted by todd.scallions
    Yeah, I see the lines in the corners. They show up in the picture more than in person. I could have used more AA or let the water circulate longer, but I got excited at how clean the pool looked. The pool did not look clear blue before the treatment. It was kind of off blue with a yellow cast. When the AA hit it started turning a clear blue almost immediately and in hindsight I should have allowed it to work longer. I'll try to do better next time.
    I looked at it again this morning and the lines in the corners do not show up unless I put on polarized sun glasses. The picture was taken with a polarized filter on the lens so they show up pretty good.
