Thread: Intex metal frame 16x48 refilling after "winter" (Florida)
    Hello all!
    Came across this site after having an unsuccessful last pool season. Well I had the pool drained and disconnected however the pool wasnt covered over our "winter" because someone through the cover away because it "got dirty". Well I have cleaned out the leaves, planning on shifting it to a new location, ordering a intex 2600 gph sand filter, and cleaning the intex SWG with vinegar.
    Now before I continue on this path to reopening the pool this weekend and spending additional money is it safe to continue? The liner had no leaks when it was drained around October and rather be safe than sorry.
    Gracias folks!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex metal frame 16x48 refilling after "winter" (Florid
    Welcome to tfp, theproj
    Quote Originally Posted by theproj
    It is not clear to me what your concern is. I would think you are good to go and setup. Make sure you study poolschool (link always at upper right), especially this article here: http://www.troublefreepool.com/pool-...ater_generator
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Read the article on temporary pools too
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Make sure the new location is level and you have supports under the legs. We see a lot of Intex's with "Help it's out of level" threads.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
