Results 1 to 7 of 7
Thread: Borax vs. Stabilizer/Conditioner
    May 2012
    Flower Mound, TX
    130
    My CYA is 100ppm, when I get my CYA in check ( 30-50) before swim season can I switch to Borax (mule 20)? Do I need to use the black dot CYA or switch to the borates test strips that I ordered with my TF100? Pool School is recommending CYA 30-50 or Borates 30-50? Thanks
    John
    14,000 gallon IG DiamondBrite pool with 2 ea. waterfalls and slide, Hayward Tristar 2.0 HP 2-speed pump, Hayward 3/4 HP waterfeature booster pump, Hayward 48sf DE filter, Hayward PS4 wireless controller, 1 skimmer and 4 returns, Polaris 280 pressure cleaner w/booster pump, 7 x 7 spa w/6 jets, TF-100 Test Kit w/speed stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Borax vs. Stabilizer/Conditioner
    No.
    They are not the same. Borates are optional, stabilizer is not. Two different tests, two different chemicals, two different purposes.
    pool-school/pool_water_chemistry
    May 2012
    Flower Mound, TX
    130
    Ok, thanks. So I would keep my CYA level between 30-50ppm with Stabilizer and Borate level between 30-50ppm with Borax. Since Borax is not necessary to balance your pool and CYA is, what is the purpose to implement Borax to your pool?
    John
    Smykowski's Avatar
    Sep 2011
    3,065
    Borax is used for 2 reasons.
    1. Raise pH if it's low.
    2. Borax can be carefully added via process that raises borate levels to approx 50 ppm. This acts as a further TA and pH buffer, plus an added benefit is the algaecidic properties inherent inborates.
    Number 2 above is optional, and should only be used after your pool is stable and you are extremely comfortable with understanding the chemistry behind BBB.
    May 2012
    Flower Mound, TX
    130
    Quote Originally Posted by Smykowski
    ok, Thanks.
    1. Can I use Baking Soda to raise PH?
    2. Since my pool is new (Mar.2013), It's best to wait on the Borax?
    1) No, use soda ash or borax to raise PH.
    2) Yes, best to wait.
    May 2012
    Flower Mound, TX
    130
    oops Thats right baking soda raises TA. Thanks Jason.
    John
