Thread: AquaLogic P4 AQL-CHEM-UPG Chemistry Chassis Retrofit kit ?
    Has anyone done this upgrade, it's tough getting someone at Hayward Tech support who is familiar with it.
    From what I understand, it is a board upgrade which will upgrade your Goldline Aqualogic P4 to a Prologic P4, as well it includes the Sense and Dispense kit.
    I remember in the past finding it in the $600ish range but you can see them selling for as high as 800ish, and I've always been curious about the sense and dispense, but I'll leave that for another thread.
    Has anyone performed this upgrade, any opinions if the investment is worth it?
    Is it relatively simple, Can I do I do it myself or is an electrician or pool tech required?
    Does a Pro Logic offer you anything over an Aqua Logic? aside from the ability add Sense and Dispense?
    18' x 36" Ovalish 80,000 Litre Vinyl IGP. 2 speed 1HP Hayward pump SP2607X102S. 300 Pound Sand Filter. Summit Sum5 Heat Pump, Goldline Controls Aqua Logic P4 System, T-CELL-15 SWG, Aqua Pod Remote Control, Pentair 7845xx02 light.
    TF-100 Test Kit, SpeedStir Stirrer, Pool Chemist in training.
    38,354
    Re: AquaLogic P4 AQL-CHEM-UPG Chemistry Chassis Retrofit kit
    I think it may also allow control of the Hayward color LED lights (?)
    I don't recommend any brand of ORP controller for an outdoor residential pool. The PH automation can be handy in some situations, especially if you have high TA fill water.
    I searched the forum and I saw all the negative responses, pity, $600ish would have been worth it for not ever having to manage the %level, just the cool factor alone.
    Not sure there any point to upgrading the board from Aqua Logic to Pro Logic then, I'll have to check on the colour LED light thingy, not sure if that alone is worth it if that's all an upgrade would prove if I wouldn't be going sense and dispense.
