Thread: Pool cover wearing deck
    Jul 2011
    Limerick, PA
    28
    Hi All,
    After opening my less than one year old pool last season, I noticed considerable wear marks on the stamped concrete (Stampcrete) from the pool cover and the retention straps. The deck is cantilevered and the rubbing on the edge of the deck is wearing the deck considerably. When we closed up for my second winter, the PB suggest putting carpet strips down on the edges of the pool last fall, which I did. However, with the wind, all the strips did was end up in the pool instead of protecting it. Just wondering if anyone else has experienced this issue and what they may have done to prevent this from happening. I think my next step is getting some 2" x 42" foam strips from Grainger and try and secure them with some string using the cover anchors.
    17x39 Rectangular, 20,000 Gal, Plaster, Pentair Easy Touch Automation and Remote
    Pentair WhisperFlow 2 hp pump with Pentair Clean & Clear Cartridge Filter
    Pentair Master Temp Gas Heater, Pentair IntelliChlor IC-40, Pentair Kreepy Krauly Legend II Cleaner
    ..and one frog that thinks the pool is his.
    Re: Pool cover wearing deck
    You can secure the carpet to the straps using wires that go through holes in the carpet pieces.
    Jul 2011
    Limerick, PA
    28
    Thanks. I was thinking the same, but I'm also wondering how long the carpet is going to last year over year. Plus I could still see the carpet shifting without counter tension. We get wind during the winter. Was also thinking I could get 2" pvc pipe to run arround the edge of the pool with a 1 inch setpack or so. This would lift the cover up. I could then secure that in strategic places from moving. Might be more sturdy and I can take it down in sections.
