Results 1 to 1 of 1
Thread: Concrete Infinity basin water proofing?
    Infinity basin water proofing:
    I need a little push in the right direction to choose a water proofing method for reservoir basin.The edge basin is concrete only and really needs to be finished.
    Background:
    After being frustrated with last water bill I shutoff my auto fill to find the culprit leak.
    I shutoff the edge pump and began to watch water levels.
    With The main pool level staying where I expected over the next couple days I moved to the basin where I suspected the leak.
    Letting the leak settle to the level right where the auto fill pipe extends in basin for the auto fill. Faulty Caulking exist here as well.
    I drained and cleaned Infinity Edge basin. This basin is approx 32x4x4. or 3500 gal
    I have already grinded out and patched my first crack at the basin fill point. I have used drylock hydraulic cement to patch this.
    Then I went on to inspect the rest of basin. There is no wonder in my mind why I am loosing so much water.
    I have found 4 more cracks in front basin wall, pitting of concrete, and even a gap in the corner with membrane showing.
    I can mend the cracks and gaps with more hydraulic cement, but where I'm having a difficult time is choosing how/what product to use to waterproof after that? I will most likely do this myself but am open to any positive experiences or feedback.
    Thanks!
    See my renovation blog here http://www.troublefreepool.com/pool-...og-t57732.html
    63k w infinity edge 60k Pool 3.5k Basin
    DE Filter AG Vinyl /Concrete basin
    IntelliFlo VS SVRS for pool
    IntelliFlo VF for edge
    AoSmith,CX p56y b2852 spa
    Pentair MiniMax NT c250 heater
    Intellitouch I9+3 Automation
    Intellichlor IC40 +IC60
