Results 1 to 8 of 8
Thread: House downspouts routed next to pool?
    Feb 2013
    Metro St. Louis
    93
    Our pool is currently being built, and we have 3 house downspout drain tiles that had to be dug up. The PB has not mentioned his exact plans for re-burying, but I have a feeling he is going to use part of the pool overdig to run the drain tiles.
    If you look in the attached picture, you will see the temporary drain tile run. I think he will run the drain tile straight out from the house, then along the pool from skimmer to skimmer, then off towards the trees.
    Question: Would you be concerned with drain tile running along the side of your pool. One one hand, there will be lots of water running along the pool...but at the same time, if the drain tile develops a leak, it would be leaking next to the pool. The other factor is that this will all be concrete decking in the end, so would seem the less digging they do, the better/compacted the soil will be for the concrete...so maybe his plan is good.
    Thoughts?
    Paul
    Sterling Steel IGP lagoon 21' x 35' w/6' deep end, Pentair 5g LED lights (x2), Pentair Landscape LED light, Pentiar IntelliFlo VS pump, Pentair 420 Cartridge filter, Pentair IC20, 4 gas Tiki Torches, LoopLoc Ultra Loc II, Deck Jets(x3), Raised Planter Bed with 3 Pentair bronze sheer decents, AquaBot Breeze 4WD, Pentair Legend II
    30,431
    Re: House downspouts routed next to pool?
    I would insist the drain lines stay away from the pool. Water inside a pool is good......water along the outside walls of a pool is NOT good.
    Feb 2013
    Metro St. Louis
    93
    @duraleigh - I agree water along the outside wall is bad. Just to clarify, the downspout drain tile is solid, not perforated. As long as it did not get a hole in it, water would not be next to the pool...however, my concern is if it did get a hole. Still thinking it is not a great idea.
    Paul
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    If he intends to run the pipe alongside the pool, and has a sound argument for it, i would insist he use 4" Schedule 40 PVC pipe for the drain. I would also be there for the covering up of said drain to make sure it is installed with a proper drop, your yard looks pretty flat.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Feb 2013
    Metro St. Louis
    93
    Good point!
    Paul
    30,431
    Any pipe placed in disturbed soil can be subject to a lot of stress because of compacting. Actually, PVC MIGHT be more prone to crack than black poly because of the flex black poly has. That said, black poly is EASILY crushed and penetrated as I know only too well....believe me!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    18'x43' Sport Pool
    Feb 2013
    Metro St. Louis
    93
    Thanks guys for the great info. I just got off the phone with the PB. He was planning to run the drain tile along his already dug trenches/pool overdig. When I expressed my concern, he said we could do it the way I wanted. However, in our contract, this was a "freebie" that they would do the drain tile work. He said the reason they could do it for free was by using existing trenches. I offered to dig the trench on the long run I was concerned with, and they will dig the trench on a shorter run on the other side. This way I can be sure the drop is correct as well.
    Paul
