Thread: 16 ft Intex Ultra Frame Pool
    Hey everyone. I'm shopping for an above ground pool and I think I'm set on the 16 ft Intex Ultra Frame. The location it is being installed at is an open area, but there is one section that will only allow for about 16 ft and 1 in of diameter on the ground. I know some pools require more ground clearance than the advertised size of the pool would indicate. I guess my question is... is the 16 foot size fairly accurate? Or do I need to account for extra clearance by getting a smaller pool? 15 ft? 14ft? Thanks for yoir help.
    KL :-)
    5,300 gal Intex Vinyl AG
    Krystal Klear 1,500gal/hr cartridge
    3/2013
    Orlando, FL
    690
    Re: 16 ft Intex Ultra Frame Pool
    I believe the instructions indicate you have to allow an extra foot around the pool. I would go with the 15 foot to allow for the clearance.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
