Thread: No Algae, Water Fairly clear, were it warmer we would swim!
    Just wanted to give a shout out to the TFP gang and say thanks for all of the posts that you guys do.
    I followed the BBB method last year including as I closed the pool with my pool builder last year. He argued with me that my pool would be green and nasty when we opened it in the spring if I didn't put a ton of his special chlorine tabs on the steps.. Yet, this is what the pool looked like 25 minutes after the cover was off and the pumps were running -
    [attachment=0:2f51ss3f]pool-opening-day.jpg[/attachment:2f51ss3f]
    BBB & Trouble Free Pool - 1, Anti-Social Pool Builder - 0
    Thanks again guys, looking forward to a great swim season here in Northern VA.
    Also, for anyone out there wondering, the winter cover was a Mesh Safety cover and we got a ton of rain here in Prince William County VA, so I had to often drain water out all winter long, so I didn't have to add any water come opening weekend.
    What I did and found it to easier was to pop the safety cover off just enough so I could pull the plugs from the return lines and I removed the dohickey from the skimmer. Then I replaced all plugs in the pumps and filter, and then primed the pump and got it running for about a week, then the following weekend (14-April) we took the mesh cover off and have put the solar blanket on.
    18' x 36' Rectangle IGP, 24K gal, Vinyl, 1.5 HP Hayward Super Pump, Hayward Pro-Series High Rate Sand Filter, Hayward Chlorine Feeder, Polaris 360 automatic pool cleaner
    38,295
    Re: No Algae, Water Fairly clear, were it warmer we would sw
    I would get a full set of test results done ... if you replaced a lot of water, your CYA might be very low.
    Casey's Avatar
    SW PA
    10,444
    I would also send a pic to the pool builder!
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Quote Originally Posted by ROTJob
    I wonder what I am doing wrong. My pool looks like a green swamp when I open it, and it is filled with frog eggs. It is covered all winter long but this has happened both years.
    Please start your own thread so we can help you more easily
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by Vette
    Thanks vette! New thread created for that poster here...pool-looks-like-a-green-swamp-t58208.html
    Feb 2008
    Denton, TX
    5,061
    Looks great!
