Thread: Best wall brush for vinyl IG?
    I need to get a new wall brush. In the past I've used the cheap ones from Walmart and our local pool store (which I refuse to ever go in again), and the plastic bristles always break off and float in the pool or end up in the skimmer basket. There's got to be a better way.
    I had a link saved that I saw here a long time ago, it was a brush with some kind of fin on it that applied greater pressure on the down stroke, but my computer crashed and it's poof gone.
    Any suggestions will be greatly appreciated
    Butterfly's Avatar
    South Carolina
    Hey, are you talking about the Wall Whale? ... ight=whale
    You're done SLAMing when:
    Apr 2008
    Indiantown, FL
    I think the brush that you are referring to is called a wall whale brush.
    Intex 16' X 32' X 52" 14,364 galllon AGP, 16" sand filter & SWG, Pool Rover & Sunrise Journey SPA 320 gallons, TechniChlor 110 SWG
    Found it.
    Then went off half cocked and ordered one
    I'll report back once it gets here.
    Wow, look at the timing on those replies
    I guess I don't need to report back. That last link says it all, I think...
