Thread: Orange county CA area pool filling services
    I folks-
    Been awhile- Does anybody know a company that can fill my pool with H20? I have way to high calcium levels and need to drain and fill. Dont want to fill with my 280 ppm fill H20. Names?
    Well water
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Orange county CA area pool filling services
    See if these guys will travel that far. They're in Escondido. You can get rid of the Calcium for good with Reverse Osmosis. http://poolservicestech.com/
    Otherwise, test your tap water. It might not be too bad. Around here they switch sources thropughout the year and sometimes its better than others.
