Thread: Re-filling pool
    RJDriver75's Avatar
    Jan 2013
    Yorktown, VA
    11
    Re-filling pool
    We just had one of the legs on our AGP replaced today because it was apparently cracked during the install last year. During the process we had to drain the pool and now we are filling it back up. Here in Virginia the pollen is crazy right now and there is a thick yellow scum on the surface of the water. My question is should I hook the pump and filter up now and start running it without adding chlorine just to keep the junk out of the pool, then add bleach when the water temp gets around 60? Or should I just wait until the temp comes up and fully open it then?
    24'x54" 13,500 gal AGP, Hayward e-100 sand filter, 1hp Power-Flo pump, Diver Dan cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Re-filling pool
    If it's full, you need to get it balanced and running. That includes bleach and stabilizer. With that pollen load in there, you'll be looking at a green swamp in a couple days otherwise. too-cold-for-algae-wrong-swamp-to-sparkle-in10-days-50-t55062.html
