Results 1 to 10 of 10
Thread: Keeping water clear when there is heavy pollen
    Sep 2011
    Atlanta Ga
    310
    I am in Atlanta and this time of year there is a huge amount of pollen in the air. Everything outside is coated with a yellow dust. Even running my pool filter 24 hours a day, the water is still cloudy, and I assume this is from the pollen. I am wondering if I should just turn off the filter, wait for the pollen to seffle to the bottom and then vacuum it up.
    Any ideas on this?
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    Re: Keeping water clear when there is heavy pollen
    Get skimmer socks and keep the skimmer going longer than normal. I think pollen can stain the pool surface. I noted someone here in Houston had a new grey quartz pool that was stained by pollen. I suggest not letting it settle.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    You can always stretch some panty hose over the old skimmer basket or install a poolskim. I run mine a LOT more than necessary this time of year, add water, and backwash when I need to. Be sure and keep your FC up-------pollen is organic and will consume it. It's a fight every year I know.
    Sep 2011
    Atlanta Ga
    310
    The pollen is filtered out by the sand filter isn't it? Why is a skimmer sock needed?
    27000 gallons
    Pool built in 1971.
    tcat's Avatar
    May 2012
    Austin, TX
    730
    I've never seen so much pollen here in Texas. Oak trees just keep dropping. Skimmer is clogged each day I get home. I scoop out one full net of it each day and 30 minutes later pool is covered again. Net weights about 20# when I pull it out. Not "that" much work as long as it ends soon.... I was just curious if it effect chemistry. My FC seems to be dropping faster than normal since it started dropping, wonder if the pollen is "soaking it up".
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Jan 2012
    'burbs of Augusta, Georgia
    7,257
    Quote Originally Posted by TomAtlanta
    I love my skimmer sock! I figure it saves the pollen reaching the filter and then later requiring backwashing out. This would save me water (replacing that backwashed out water) as well as my labor and time.
    My skimmer socks collect large amounts of the fluffy wet yellow pollen. I just try to make sure I change them out daily and rinse them out for reuse.
    Yes, but, as you see, your pool is not clear. The sand filter can chew up the debris but it takes time to turn it all to clear liquid. At this time of year you should give it a hand and remove that debris before it gets into the filter.
    I've got large trees on 3 sides near my pool... I'm using 2 poolskims and so far they are doing a great job on popular flower pettles,,pollen,, and wayward bugs..... May want to try a poolskim,,,or 2...
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    tcat's Avatar
    May 2012
    Austin, TX
    730
    Those look pretty cool. How fine is the bag that comes with the Poolskim? Finer than a leaf net? I like the idea of working off an inlet fitting (I have 4)... can be moved to the downward wind direction.
    DIY chlorine feed
    BBB
    Check their website, I haven't looked at it in awhile but they may have small mesh bags listed. I'll have pollen in early morning but the skims catch it. Could be because of pettles,leaves filling the bottom and pollen being stopped in them.
