Results 1 to 8 of 8
Thread: Test Results
    Mar 2013
    Wichita, KS
    11
    Test Results
    So I got my test kit in and the pool is starting to get put up. I decided to run the tests on the tap water that we will be using to fill the pool.
    Here are my results:
    pH >8.2
    FC 0.5
    CC 3
    TA 120
    CYA <20 (I could still see the dot at the bottom)
    How are these results?
    18x33ft oval AG, 15,000 gallons
    22" BlueWave Sand 1.5hp
    04/2013
    I use and endorse the TFtestKits TF-100 from http://tftestkits.net
    22,551
    Re: Test Results
    You're going to have a bit of work to do once you get the pool filled but you've made a good start by testing your fill water. Tap water won't have any CYA but running the test was good practice.
    You'll need some acid to get the pH down and some chlorine of course.
    You're TA isn't too high so I'd just let it come down as you adjust the pH as needed.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Test Results
    How about CH, this is one of the more important factors in fill water as it builds up over time (concentrated due to evaporation) in the pool
    Mar 2013
    Wichita, KS
    11
    Re: Test Results
    Quote Originally Posted by Isaac-1
    I guess I forgot about the CH because i thought for Vinyl it was unimportant but I will run that test next time. Thanks for the help.
    :P
    04/2013
    22,551
    Re: Test Results
    Good catch Isaac!
    It's not important if it's too low but it can be if it's too high.
    It's a good idea to run the test just to know where you are.
    Mar 2013
    Wichita, KS
    11
    Re: Test Results
    I was pleasantly surprised as to how easy it was to run the tests. I was really worried that it would be over my head but now I feel much better!
    04/2013
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Test Results
    CC 3 on tap water?
    Surely it wouldn't be that for the full fill, I could see initial flow as having some CC from water sitting idle. Would this be a concern for your drinking water?
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    22,551
    Re: Test Results
    Some municipalities use monochlorimine as their sanitizer which shows up as CC on the test kit. It will go away pretty quickly once it's in the pool.
