Results 1 to 13 of 13
Thread: Vinegar to Lower pH
    Apr 2013
    Dallas, TX
    59
    Vinegar to Lower pH
    This is purely hypothetical, not something I would actually try, but could distilled vinegar actually be used to lower pH? If so, what other side effects would it have?Would it effect any other readings (TA, etc)?
    Again, not something I'm actually considering - just an idle thought.
    ~15k gal IG pebble pool/spa w/ water features, Goldline ProLogic + SWG, 2x Hayward Northstar pumps, Hayward Booster Pump, Hayward 60sqft DE filter, 400k BTU Hayward heater, Hayward Viio Turbo pool cleaner, TF100 test kit
    Mar 2007
    San Rafael, CA USA
    12,085
    Re: Vinegar to Lower pH
    Household vinegar is fairly diluted at only 8%. It's acetic acid which is a weak acid, but with a pKa of 4.76 that's low enough below pool pH that it behaves much like a strong acid in terms of lowering the pH, but of course takes a lot more volume of it to move the pH since it's so diluted -- because of molecular weight differences, Muriatic Acid which is 31.45% Hydrochloric Acid is (31.45 * 60.05) / (8 * 36.46094) = 6.5 times more concentrated on a molar basis than household vinegar. Unlike Muriatic Acid that just leaves chloride ion leftover, Vinegar leaves acetate ion so an organic molecule. Though it doesn't react readily with chlorine, we generally don't add extra chemicals to the water that aren't needed.
    [EDIT] In addition to lowering the pH, it would lower the TA in the same way as Muriatic Acid since the pKa is so low. Technically, it increases TA if you add enough of it though I'm not sure it would be that measurable -- the TA test measures chemicals that accept a proton down to a ph of around 4.5 so the acetate ion may be at least partially measured as TA. [END-EDIT]
    Feb 2008
    Denton, TX
    5,062
    Probably wouldn't make the pool smell all that good either.
    Apr 2013
    Dallas, TX
    59
    Would it do anything to CH?
    Mar 2007
    San Rafael, CA USA
    12,085
    No. CH is Calcium Hardness and acetic acid has no calcium. It's just a simple organic acid.
    Apr 2013
    Dallas, TX
    59
    Yeah, I knew it wouldn't *raise* it, but I wonder if it would lower CH. I'm just thinking of how you can use it to remove scaling
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If what you are getting at is removing scale then this is the proper process: http://www.troublefreepool.com/ascor...ins-t2298.html. Post a full set of test results and we can help.
    Apr 2013
    Dallas, TX
    59
    No no, this is all just idle speculation - I don't even own a pool (yet)
    I'm thinking if you can use vinegar to remove limescale off of kitchen items, would it "remove" calcium from the water (ie lower CH)?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Well, then the answer which has already been stated...is it is better to use Muriatic Acid since the acetic acid will leave acetate where the MA will only leave salt (starts as chloride ion and often finds Na to form salt). Also MA will be much cheaper(you will use a lot less 31.45% MA then 8% Acetic). Vinegar is not a bad choice for cleaning swg cells however...
    Mar 2007
    San Rafael, CA USA
    12,085
    As was noted, it's the acidity that removes calcium carbonate scale, not the specifics of the acid itself.
    Apr 2013
    Dallas, TX
    59
    what's that acetate ion do? just hang out?
    Mar 2007
    San Rafael, CA USA
    12,085
    Pretty much yes, though it will very slowly react with chlorine to form some chloroacetic acids and these haloacetic acids are regulated disinfection by-products in drinking water since they are potentially carcinogenic. Again, we generally recommend against adding anything to the pool that is not needed.
    Apr 2013
    Dallas, TX
    59
    good to know!
