Thread: Swg startup
    Swg startup
    I just completed installation of my pentair intellichlor. After my initial startup to test the equipment, the swg showed the salt level to be good (all lights green). The only problem is I have not added any salt to the pool. I am taking my water in the morning to get tested but wanted to see if there are any other issues I need to possibly be aware of.
    Oct 2012
    209
    Re: Swg startup
    I do believe you are supposed to add salt to the pool before you turn on the generator, or it will be miscalibrated.
    24' round above ground, 13500 gallons, vinyl liner, 18" Sand Filter
