Thread: Can I shut off my pump for a week without a problem
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Would it be Ok to turn off my pump for a week if I'm going on vacation. Pool will be fully covered so no contaminants can get to the water. Current pool chemistry is:
    pH = 7.5
    FC = 3
    CC = 0
    TA = 90
    CH = 320
    CA = 40
    B = 45
    Temp = 70F
    Water looks crystal clear
    I was going to lower my pH a little, because plaster is 6 months old and pH does rise a tenth or so every few days. I was also going to boost my FC to around 5 or 6.
    I'm thinking this will be just fine, but I thought I'd better be safe than sorry and check with the experts.
    Thanks
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,573
    Re: Can I shut off my pump for a week without a problem
    You may be gettin' kinda chancey with the water that warm and no circulation. Considered a timer?
    Jul 2009
    Olney, MD
    218
    How come you want to shut it off? Why not run it while you are gone?
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I'm just not real confident with the condition of my plumbing and my old pump motor.
    38,262
    You should raise the FC up to shock level (FC of 16ppm) before you cover the pool. Circulate it for at least an hour before you turn the pump off.
    It would be better to have the pump on a little bit each day just to circulate (even 1-2 hours).
    Even with these precautions, you may return to some green and need to go through the shock process.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Understand. Maybe I'll spend my time before vacation fixing the plumbing problems, etc. Thanks for your guidance.
