Thread: Salt level too high?
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Just added salt for the first time to my new pool. I started with a 23000 gallon pool, with salt reading of 400ppm. According to Pentair, I want to keep the pool around 3500ppm, but anywhere from 2800 - 4500 will work. After consulting with the Pool Calculator, it said to add 597 pounds of Salt, which was fifteen bags. Thinking I didn't want to go over too much, I withheld a bag. After testing 24 hours later, using the Taylor Salt testing kit (not strips), I'm sitting at 4000ppm. Going back to the calculator, it says to empty 2900 gallons.
    Do you think I should empty some water, or is 4000ppm not that bad for the equipment?
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    38,463
    Re: Salt level too high?
    4000 should be fine. It will slowly come down due to backwashing and splash out.
    It is more important what the IC40 thinks the salt level is. Circulate for 24 hours before turning it on.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    I started out at 4000 myself last year. You will be just fine.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
