Thread: Tis The Season
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Tis The Season
    It beginning to feel like swim season again. Water temps have creeped into the 70s. The pool is sparkling and ready. This will be our second season with the SWG. It shut itself off when the water temp got below 62, but we never had to add chlorine. It kicked right back in when the water temps climbed.
    I completed a full compliment of tests yesterday, and other than a little acid to lower pH, I added couple of pounds of CYA, which I am sure I lost over the winter due to Rain, Backwashing etc.
    Looking forward to living vicariously through many of you again this year.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    38,449
    Re: Tis The Season
    My solar setup had our pool over 80 degrees a few week ago ... a little cooler now though since I do not use a cover.
