Thread: Using Air Conditioner as Pool Heater/Condenser
    May 2011
    Mesquite, Tx
    8
    Back when I was in HVAC circles there were a few guys that tried this on their own with limited success, has anyone on TFP boards tried this?
    http://hvac-talk.com/vbb/showthread.php ... uperheater
    http://hvac-talk.com/vbb/showthread.php ... mming-pool
    http://www.hotspotenergy.com/titanium-p ... xchangers/
    May 2014 New Plaster!, 19,000 Gallon In-Ground Kidney Shaped Gunite, 1 HP Pump, 350 Lb Sand Filter, Polaris 380/PB4 Booster Pump, converted to BBB method April 2012
    Re: Using Air Conditioner as Pool Heater/Condenser
    It is quite unusual to hear of people trying this, though a few people here and there have mentioned having something like that.
    The main issue is that the heat available and the heat needed don't match up very well, so you don't get much for the expense of installing the equipment. Pools need the most heat in the spring and fall, a time when air conditioning is not getting used very much. The further north you are the better to matchup, as you are more likely to want to heat the pool in mid-summer when heat is available from the house. But even then the total amount of heat available isn't all that large compared to what a pool typically needs.
    Jul 2011
    St. Paul, MN
    244
    I saw this on an episode of "Ask This Old House". http://www.thisoldhouse.com/toh/tv/a...652494,00.html
    As Jason points out, this isn't going to do much to heat your pool. Buy may help reduce your A/C bill?
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
