good morning,
It is a mpn5x12-6 which has a slightly lower min flow rate than the one you chose, but regardless of that, I decided to use it because it said 20gpm max flow rate and I thought the Pentair would do all of that even at a lower rpm. I also thought 20gpm would be enough to filter the spa, that's why I put the filter and heat together in the same loop. I guess I don't understand all the losses in flow and pressure. Do you think the low flow rate will filter the spa enough?
As far as the switch, it is set as low as it can go and the plumber gave me that one. I am not sure where to buy a weaker switch
