Thread: Question for someone else testing flow sensor
    Jun 2012
    Goochland, Virginia (outside of Richmond)
    32
    Can anyone help me out with this, so I can pass the information along.
    "I've got a goldline controls Aqua Rite automatic chlorine generator. It's showing NO FLOW when my pump is running.
    The connector from the flow sensor is good.
    The cable from the flow sensor is good.
    How can I check the flow sensor?
    Does it put out a voltage when it senses a flow?
    Should there be continuity when there's no flow or the other way around?
    What should the continuity read?"
    Thanks again for any help given.
    Pointed them to this site as well, hopefully they will come along and join up.
    16,800 16'x32' IG Vinyl Pool, Buddy Seat, 7' Deep End
    Hayward Sand Filter(1.5 cups of DE), Pentair Pump, SWG Autopilot Digital
    Taylor K-2006 test kit, Speed stir, Borate and Salt Water Strips
    Polaris 9300 cleaner
    Pool Filled First Time June 14th, 2012
    Previous Pool AG Intex 16' Oval, SWG (5 Years)
    22,550
    Re: Question for someone else testing flow sensor
    There should be continuity with water flow.
    Here's a thread that has a picture of it. You can short the terminals for the flow sensor and the swg should start working if it's a bad flow switch.
    Jun 2012
    32
    Thanks Bama, I told him answers would start coming in pretty fast from this site.
    Most helpful place on the internet bar none.
    Jun 2012
    32
    Bama
    Once again thanks for the info, I passed it along and after a few test new flow sensor ordered.
    Hopefully i can drag some new members in here.
    22,550
    Glad you got it figured out.
