Thread: Pumping time length
    Pumping time length
    Tried searching the forum but not finding anything. How do you determine how long to you run your pump each day. ZxAverage 85 degrees. 2 speed-14000 gallons
    Thoughts?
    Thanks
    Shawn
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
    30,419
    Re: Pumping time length
    Actually, you run it long enough to keep the pool looking like you want. We generalize to start with an 8 hour daily run time and then move it up or down depending on how satisfied you are with the way your pool looks.
    Mine does pretty good for about 8 hours daily except I move it up to 10 in the Spring (with all the falling tree junk) and then 12 or so when active swim season begins.
    4 hours in the cold months is all I need.
    Your pool will be different but it might be a starting point.
    Thanks.. Are any of the hours in low mode, split or all high mode pool pump?
    Shawn
    For normal filtering and circulation you use low speed (if you have it).
