Calculating pump rate
Mar 24, 2013
69
NW GA
I have a 2.7hp variable rate pump/timer by AO Smith. Side label attached
Any idea how to calculate pump flow so I can determine run time and rate?
I know the swg needs 2175rpm (25% max flow) to operate.
I know the swg needs 2700rpm (55% max flow) to operate while the Kreepy Krawly vacuum is in the pool.
Help?
TIA!
Flow rate is determined primarily by the following:
Plumbing setup - Pipe lengths, fittings, equipment, etc.
Pump wet end - What is the motor attached to?
Motor speed
But required run time for a pool doesn't really depend so much on flow rate. The simple solution is to run the pump long enough to keep the pool clean and chlorinated.
Ha. Thank you.
That's not specific enough ;-) I'm not a fan of trial and error. LoL especially if (a) I error or if (b) I waste time/money on starting too high.
Thank you for your response!
I guess I'll start it at the min speed 12 hours a day and see from there.
