Thread: Calculating pump rate
    Mar 2013
    NW GA
    69
    I have a 2.7hp variable rate pump/timer by AO Smith. Side label attached
    Any idea how to calculate pump flow so I can determine run time and rate?
    I know the swg needs 2175rpm (25% max flow) to operate.
    I know the swg needs 2700rpm (55% max flow) to operate while the Kreepy Krawly vacuum is in the pool.
    Help?
    TIA!
    26900 gal IG Vinyl (18'x36', 3' shallow end and 8' deep end plus steps)
    sand filter and 2.7hp variable speed timer
    Jandy Ei SWG (2yr old)
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Calculating pump rate
    Flow rate is determined primarily by the following:
    Plumbing setup - Pipe lengths, fittings, equipment, etc.
    Pump wet end - What is the motor attached to?
    Motor speed
    But required run time for a pool doesn't really depend so much on flow rate. The simple solution is to run the pump long enough to keep the pool clean and chlorinated.
    Mark
    Mar 2013
    NW GA
    69
    Ha. Thank you.
    That's not specific enough I'm not a fan of trial and error. LoL especially if (a) I error or if (b) I waste time/money on starting too high.
    Thank you for your response!
    I guess I'll start it at the min speed 12 hours a day and see from there.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The simplest answer may be to invest $150 or so in a good flow meter and plumb it into your pad, then you will know what is going on and you will not have to guess.
