Results 1 to 11 of 11
Thread: Replacing Pump & Filter and Need Advice
    Hello Everyone and THANKS in advance for any advice
    I have an 18x36 in-ground liner pool here in Massachusettes. The whole pool is 4.5' deep except for about 16x6' area at the steaps which is 3' deep. I have 1 skimmer mid pool with an 1 1/2" line back to the pump (40'). I have a main drain mid pool back to the pump 1 1/2" x 30'. There are 2 returns, 1 is at the end facing the length of the pool 1 1/2" x 20' back to the filter and the other on the opposite end but on the side wall 1 1/2" by 55' back to the filter. There is also a 1 1/2" by 35' line that feeds 3 returns into a swim out on the opposite side with a few seats. No fountains or anything so basically everything is a homerun back to the filter. The current setup is a Hayward DE4820 Filter and Hayward Super Pump C48K2143B1 (picture attached)..The pump is very very loud now and the a few of the cartridges in the filter have small rips leaking DE back into the pool. I would like to to replace the entire set up with something quiet and efficient. Being here in Southern New England the electric bills are crazy and if I run 24hrs a day it adds about $150 a month to the bill. Any advice appreciated
    38,305
    Re: Replacing Pump & Filter and Need Advice
    Welcome to TFP!!!
    I am estimating you are around 16k gallons, so your filter is already the size we would recommend. For less than $150 you can get a whole new set of grids off Ebay. I would go that route instead of buying a whole new filter.
    Can you add a picture of the motor label? I do not find anything for the model # you posted.
    The cheapest fix for the pump would be to just replace the motor. Either going with a 2-speed that could be run on low most of the time and save a lot of electrical cost or there is a newer variable speed Super Pump, that you may also be able to just buy the motor and put on your existing pump.
    30,424
    A bit off the subject but running 24/7 is overkill by a lot. Most of us run 6-8 hours daily in swim season and a bit less in cooler months.
    Run time can vary quite a bit but there is no need to run 24/7.
    Hi Jason..thanks for the reply...here is a picture of the pump
    Hi duraleigh..I don't always run 24x7 but I happen to live in coastal area that is considerably windy the majority of the time so although I have taken down everything I can around the pool I still have to deal with the neighbors trees etc which keeps my skimmer pretty busy.
    30,424
    I understand now.
    BTW, your equipment area is pristine. I don't think I have ever seen one so well kept up.
    38,305
    LOL ... I can not read anything on that picture ... slightly out of focus and the flash glare ... care to try again?
    Hopefully this is a little clearer, thanks
    38,305
    OK so it is a 1.1 SFHP Super Pump. (There is someone else currently looking to replace the same motor here: help-me-pick-a-new-pump-t57622.html)
    Anyway, do you know if yours is 115V or 230V?
    You can find a replacement 2-speed motor and seals for less than $300 ... then would need to add a speed switch (I saw a Hayward rear motor cover with a switch for $35).
    Jan 2012
    340
    Take a look at the new super pump vs too.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    38,305
    Quote Originally Posted by thepoolman
    Do you know if just the motor is available? And roughly how much?
    Jan 2012
    340
    The motor looks to basically be one of the impower motors. The differene is that you can actually adjust the high and low speeds. Not sure what they are online, but the whole pump retails for 750. You could always just remove the power end and stick it in the existing wet end so no plumbing work needs to be done. Either sell new wet end or keep for a spare.
