Results 1 to 7 of 7
Thread: Aerating TA
    Mar 2013
    NW GA
    69
    Aerating TA
    All the posts and articles I am reading about TA uses acid and aeration to lower the levels.
    I shocked my pool with trichlor and am adding CYA, both of which lower the pH. I am aerating via aiming the return jets upward - plus my pool gets maybe 4-5 hours of GA sun per day.
    Is aerating a low pH enough to lower TA? Or is the TA specifically related to the muratic acid?
    26900 gal IG Vinyl (18'x36', 3' shallow end and 8' deep end plus steps)
    sand filter and 2.7hp variable speed timer
    Jandy Ei SWG (2yr old)
    38,248
    Re: Aerating TA
    TA only goes down when you lower the pH.
    Aerating only raises the pH ... so that then you can lower it again and get the TA to go down as well.
    Mar 2013
    NW GA
    69
    Re: Aerating TA
    Ok. So trichlor and CYA are both effective at lowering TA?
    38,248
    Re: Aerating TA
    I am not sure I would say "effective" as they do not lower the pH nearly as much and as quickly as MA, but they should help.
    Mar 2013
    NW GA
    69
    Re: Aerating TA
    Thank you so much!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,729
    Re: Aerating TA
    Just keep a sharp eye on your CYA level...Trichlor adds CYA, which if it creeps above 80 ppm could cause issues.
    Mar 2013
    NW GA
    69
    Re: Aerating TA
    Pool is good and shocked now and the FC/TC/CC numbers are at target level. CYA is about 40ppm too low. I added 10lbs CYA Saturday and was advised to wait 6 days before adding more.
    Thanks for your feedback! I'm getting this all figured out.
