Results 1 to 10 of 10
Thread: What depletes CYA?
    Mar 2013
    NW GA
    69
    What depletes CYA?
    My test kit came in Saturday. (Baaaaad idea y'all for me to have test kits. I want to test everything every day multiple times a day just to see what's going on!!)
    First test 4/13
    FC - 0
    TC - 1
    pH - 8.0
    TA - 130
    CH - 120
    CYA - 0
    Salt - 2320
    I added:
    5lbs trichlor
    10lbs stabilizer (CYA)
    1 quart muratic acid
    8x 40lb bags of salt
    And turned the return jets upward to aerate
    (Turned the swg off to let salt dissolve)
    (I added the CYA in a pair of pantyhose and hung it in front of a return jet. It was completely dissolve from the pantyhose within about 24 hours. )
    Second test 4/15
    FC - 5
    TC - 5
    pH - 7.4
    TA - 100
    CH - 120
    CYA - 40
    Salt - 3800
    So now I'll turn the swg on maybe 20% and monitor TC
    Pool calculator is telling me 6 more lbs of CYA to get to 70. At $20 per 5 pounds this stuff is expensive and I'm hoping to not have to add it often!
    What causes CYA to deplete and how often should I expect to have to add it?
    26900 gal IG Vinyl (18'x36', 3' shallow end and 8' deep end plus steps)
    sand filter and 2.7hp variable speed timer
    Jandy Ei SWG (2yr old)
    Mar 2013
    NW GA
    69
    Re: What depletes CYA?
    I haven't tested my fill water yet. More tests to run!
    May 2011
    Montgomery, TX
    176
    most everyone on this board says only water replacement lowers cya, but I have found in my pool that hypochlorite in bleach and cal-hypo oxidizes and lowers cya to the tune of about 5-10 ppm per month.
    Most people only need to add CYA once per season.
    Oxidation of CYA can happen but it is much slower than that, perhaps 2 ppm/month. Mostly CYA is lost when you replace water, for example when you backwash or winterize, and occasionally CYA will vanish over the winter.
    I'd give you some of my CYA, but it's all in the water :0
    19,500gal, Gunite, Pebbletec, Chlorine, PCC2000 cleaner, Stenner Chlorine Pump, MegaCatch Mosquito Trap
    Wait before you add more cya yer I recall even if disolved it can take several days to register on test
    24' 52" Above Ground
    BBB
    LOVE TFP
    TF Test kits, Pool School, Pool Calculator
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by imwarren
    This is a good point by imwarren. Adding 10 lbs to your 24000 gallon pool should raise it up 50 ppm. It can take up to a week for cya to show up. In addition, there are a couple of reasons to wait to add more, one is knowing your pool volume accurately, and two, there may have been a small amount of cya in the pool even though you read 0 (unless you just refilled the pool or know the full history of the water). I would wait to add more until ~6 days go by and test again.
    Mar 2013
    NW GA
    69
    Okay. Thanks, y'all.
    So should I add muratic acid to lower the pH in order to keep working on TA for now?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you are still at 7.4, I would continue to aerate up to 7.8, then drop it back down.
    Mar 2013
    NW GA
    69
    Edited my sig. Measured pool depth. I had estimated 7' deep end but it's 8'. I measured the step depth too and calculated it all in pentair volume calculator.
    Just tested fill water.
    TC - 0 (good)
    pH - 7.2
    TA - 140
    I didn't test CH since my pool is fine on CH an a wide range is acceptable.
    I didn't test CYA because tap water shouldn't have any...
    So hopefully the kids can splash out any extra TA over the summer as we refill the pool!
