Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Intex Pool w/DIY Skimmer Question
    I saw someone used something similar to this http://www.amazon.com/Hayward-SP1091LX- ... PDKIKX0DER and cut the liner.
    I saw the forum post but all the pictures are dead and I can not see them any longer,
    I wanted to know what distance from the top of the pool you would install this at, also, I wanted to use the larger outlets on this pool and wanted to know about cutting the existing small hole from the 10x30 intex to the larger one.
    I am just tired of the in pool skimmer the kids think its a toy, and it also takes up swimming space.
    15k in-ground pool and spa || Dark Blue PebbleSheen Finish || Pentair DE Filter || Pentair VS+SVRS Pump
    22,550
    Re: Intex Pool w/DIY Skimmer Question
    There are a few threads about people installing a standard thru the wall skimmer in an Intex pool. The largest one is the one with the picture links broken.
    There was a thread where someone installed it above the welded seam of the overlap and used thick gaskets to makeup the difference and it worked well. That's the highest I recall seeing anyone install one. Normally it gets intalled with the top lip of the skimmer right under the welded seam.
    Here's one thread. It's a rectangular pool but the steps are the same.
    Just use the Google search at the bottom left of the page and search for wall skimmer intex and you'll find plenty of examples with pictures.
    Mar 2013
    Oklahoma
    25
    I actually bought that very model and installed it yesterday. It was pretty simple. From the outside of the pool, I took the trim ring and traced the interior outline (the part that would be cut out) onto the pool. I was lucky enough to have the sun facing me, so I was able to see where the shadow of the welded seam stopped. I placed the top of the trim ring about an inch down from that shadow line and made my marks. The rest is as simple as following the instructions in the manual. If you'd like, I can take pictures when I get home from work and post them.
    @ Williamshelton1972, I'd love to see the pics of your skimmer. Can you tell me how you hooked it up to your pump? What size pvc did you get? Etc. Thanks and I look forward to seeing your pics.
    McKinney, TX
    Pool build in progress, 14.8K gallons, OK flagstone copping (sealed), IG Gunite/Pebblesheen (Blue Granite), Pentair intelliflow 3050 vs - svrs, Pentair IC20 Salt-Gen, 60 sq ft Pentair DE filter, 400k BTU Pentair (NG) heater, Polaris 280 with Booster, Dual Time Clocks with freeze protect feature, Pool (1) 500w (1) 100W Spa (1) 100w lights, (2) Skimmers, 4 Pool Returns, 6 Spa Jets, water features incl (3) 12” scuppers on 12” x 31’ raised beam, (2) Gushers on tanning ledge, and double cut spa spillway. controlled by easytouch 8
    http://www.troublefreepool.com/under...t56120-40.html
    Mar 2013
    Spring, Texas
    14
    My skimmer arrived yesterday and I'm planning on installing it this weekend. My dilemma is this... I want to use the butterfly gasket as intended, however I'm worried that if I just cut a hole by tracing the pattern, the geometry of that hole will change due to the weight of the water pulling down once the cut is made. The alternative seems to be to basically install the whole device on the wall first, (bisecting the gasket into to separate pieces) screwing the plate through the wall THEN cutting out the hole and leaving things alone..
    Did you just cut the hole then assemble? Did the shape of the hole distort much? How close to the bottom of the hole was your water level? Thank you!
    Intex 16'x48" Ultra-Frame. Hayward Thru-wall skimmer mod. Adjustable Fountain. Hayward SP1593 1-1/2 HP Power-Flo Matrix Pump. Hayward S116T Pro Series 16" Top-Mount Sand Filter.
    Apr 2012
    SW Ohio
    456
    I would not try to cut the hole for the skimmer first it will distort. Cut the butterfly gasket into two pieces with a razor knife or.go the the pool store and buy two rubber gaskets......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    My husband went ahead and installed ours yesterday. He traced the
    interior of the gasket and he made the cut. After cutting it, he inserted the gasket in between front & back of liner. The screws were very hard to get into the skimmer that hangs on outside of pool but we did it and it is working really well. We love it.
    McKinney, TX
    Mar 2013
    Oklahoma
    25
    @laracohran, apologies for not replying sooner. I kept forgetting to check for replies to my post in this thread. I read that you've already got yours installed, but I'll get some pics posted here in a few minutes anyway. I patterned my plumbing after fast1971chevelle.
    http://s1332.photobucket.com/user/willi ... %20Skimmer
    @Khaphora, I had my pool full up to about 2 inches below where I wanted to put the skimmer, which made the side of the pool completely rigid. I also didn't cut my butterfly gasket into two pieces so that if I ended up being a little off on my hole, I wouldn't have to worry about getting things lined up exactly. As you can see in one of the pictures above, my initial position was a bit high...and would have led to the trim ring being installed on the vinyl weld on the inside of the pool. I was also a big concerned about the weight of the skimmer(with water) distorting the side of the pool, but so far that has not been the case. The piping seems to be rigid enough to prevent any issues, although if it does become an issue in the coming years I can simply add a support below the skimmer piping. Also, all pipe used is 1 1/2 inch, with the exception of the fountain which was stepped down to 1 inch.
    As a testament to the salt-water system, notice the awesome shade of green has disappeared. My daughter has even braved the cooler waters to swim a little already, although it's still a bit too frigid for my liking. Next on the agenda is coming up with some sort of heating method.
    Mar 2013
    Spring, Texas
    14
    Thank you. I'm going to try it like you, without installing the skimmer prior to cutting. I've read several reports of people doing it that way with the round pools without the hole distorting. The one I saw that did distort was a rectangular pool. I'll do a horizontal test cut to check for downward pull/distortion and then go for it if nothing seems out of the ordinary. I just like the idea of using the butterfly gasket as intended, reducing the potential leak "zones" from four to two, and keeping the exposed fibers in the cut liner from constant water exposure.. Perhaps a bit paranoid, but hey...
    @williamshelton1972, your pool looks so clear and sparkling clean Did it get that clear from the salt water system only? We are thinking of getting one too. Thanks.
    McKinney, TX
    Mar 2013
    Oklahoma
    25
    @laracohran, pretty much. I had some leaf debris in there early on, before I had the skimmer connected and working. After I got the debris cleared out and the bottom vacuumed I put the SWG on the boost cycle a few times, which as I understand it, is like a typical pool shock treatment. I've been running everything normally though and havent' added any chemicals, although towards the end of the month I'll take a sample to the local pool store and have it tested.
    Mar 2013
    Spring, Texas
    14
    Ok that was easy and painless. Ill post pictures later but the skimmer install was a snap. There was no distortion at all when cutting the hole. I'm plumbing it all back together now (essentially from scratch as my intakes and outlets are changing positions) will post a separate thread later. Thank you for the tips and pics.
    Mar 2013
    Oklahoma
    25
    @Khaphora, good news. Glad to hear things went smoothly.
    Mar 2013
    Spring, Texas
    14
    Here are a few pics. The intake plumbing will be hidden under the mulch. There is one ball valve upside down due to salvaging the part. Nothing is glued yet; that's why the fountain is strapped and low. Oh, I added a second intake. This second hole was below the water line. Lesson: don't use water based marker to trace your circle if water will be gushing out once a cut is made.. I stuffed it with a Walmart bag, traced again and cut out the circle and put the intake in quickly once the cut was finished.
    Mar 2013
    Spring, Texas
    14
    One more as it only let me post three
    Oct 2012
    Central Ohio
    180
    You must be in Australia
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    Quote Originally Posted by CB
    :P
    ....bahahahaa
    Intex Ultra Frame 18' x 52"
    Intex 3000 gph Sand Filter Pump, Intex Salt Water System SWG
    Hayward Thru Wall Skimmer and stock return line
    Two Hayward I lets
    Florida/Alabama
    Mar 2013
    Spring, Texas
    14
    Strange that they're showing upside down for others but normal to me. Tell me if this one shows up right.. I rotated it (upside down as I see it).
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Quote Originally Posted by Khaphora
    its upside down.
    your "the hole pic" is the only 1 i see right side up.
    Intex Ultra frame 16x48
    Intex 1600GPH Sand Filter
    Taylor K-2005 test kit
  20. Back To Top    #20
    Mar 2013
    Spring, Texas
    14
    Well I give up then. if they're upside down when they look normal to me and upside down when I rotate them 180 and re save them, I'm out of ideas.
