Thread: Rock in skimmer basket. OK?
    Is it OK to use a rock (bigger than pipe opening) to hold the skimmer in place? It won't effect the pool chemistry in any way will it?
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Rock in skimmer basket. OK?
    Lots of people do it, myself included.
    38,397
    Me too.
    You could also try to replace the skimmer basket with a heavier grade basket if it is available. I found that Warehouse Pool Supply here locally carried a few baskets that fit my skimmer. The heavy one has a lip on one edge that helps to lift it out and the whole thing is so heavy that I no longer need to use a rock to keep the basket from floating.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by Thinkly
    Just make sure the rock is bigger than the pipe opening in the bottom of the skimmer.
