Thread: Sealer for Aggregate Pool Deck
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    I have an exposed aggregate pool deck that is 30+ years old. The prior owners didn't keep up with the maintanence and the exposed aggregate is really exposed and hurts my feet. In a few years, I plan to replace the deck, but want to add a sealant to soften the feel on my feet.
    I've heard that regular glossy concrete sealant isn't recommended for pools because they make a surface slippery. Which product would help me seal the aggregate to make is less rough?
    Thanks!
    Karen
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    dafuzz's Avatar
    Apr 2013
    North Florida
    66
    Re: Sealer for Aggregate Pool Deck
    I too have this issue, though not quite as bad. Have you looked at Garage Floor/Porch epoxy paint?
    There's also a type of rubber epoxy paint that may also refresh your deck. Search for Ramuc or the like. Pricey stuff
    ~31k gallon 18x36 IG, Vinyl LoopLoc Sahara, Hayward C-750 75sq' Cartridge filter, Pentair Intelliflow VS3050, SGS Breeze760 SWG, Homemade Aerators, SmartPool Nitro 52 Wall Climber, TFT100 XL, Borates, and a partridge in a pear tree :)
    May 2013
    Kentucky
    29
    I have a similar concern with my exposed aggregate patio. The patio is huge as it goes around the pool and connects to the house, so replacing it isn't currently an option. There are cracks throughout it so I have been looking at a way to repair/conceal the damage. I came across a new product at the local hardware store the other day by RustOleum called Concrete Restore that may work. It is a very thick substance that adheres to concrete. I think it would completely cover the aggregate, but it may take a lot of it to fill in all of the cracks & gaps between the stones. I could only find information for putting it over normal concrete so I don't know if it will bind to aggregate correctly.
    20 x 45 ft Roman Lazy L, 28k Gallons, Vinyl, Pentair Triton II TR-100 Sand Filter (600 lb), 1.5 HP pump + Booster pump for Polaris 280, Hayward Gas Heater H300, Hayward T-15 SWCG w/ AquaRite digital controller
