Results 1 to 10 of 10
Thread: short blast of DE at pump turn on?
    Just moved to a new house with a pool. Iv'e noticed when the pump first turns on it appears that a blast of De comes out of the jets. It only happens at start-up for a few seconds and then stops? Im assuming its DE. If there were a rip in the filter wouldn't it spray DE all the time when running???
    62,800 Litre IG Vinyl
    Sand Filter
    1HP Super Pump
    Clearwater/Zodiac LM2-24S SWG
    Aquabot Turbo Robot Cleaner
    250K NG Heater
    30,414
    Re: short blast of DE at pump turn on?
    make sure it's DE first. scoop some out of the pool.
    There's not enough to scoop. Just a quick gray cloud out of the jets when the pump first kicks on......
    Sand Filter
    1HP Super Pump
    250K NG Heater
    38,271
    Does it only do this when switching back to filter after backwashing? Or does it do it every time the pump is turned on?
    The former seems to happen to some people (I have never seen it). The latter should not be happening.
    It happened after I backwashed and added DE again. I have a multi-port valve. I am not very familiar with this type of valve. I was running for a few minutes on recirc. I thought that on recirc it just bypassed the filter??? Could that have something to do with my issue?
    Sand Filter
    1HP Super Pump
    250K NG Heater
    38,271
    Correct, recirculate skips the filter ... why were you using that setting?
    The normal backwash routine is backwash, rinse, backwash, rinse, repeat as needed until the water is clear when backwashing. {Always turn off the pump when changing the valve}. Some people add the DE in the Rinse setting so that nothing that sneaks through goes back to the pool. I have always added the DE on Filter and do not see anything go back to the pool.
    It did not happen today when the pump kicked on. I'm assuming its something that occurs after backwashing and adding the DE. Either that or all my DE was pushed into the pool. Im assuming if that were the case the DE would settle on the bottom and be visible? My filter holds 10 lbs of DE
    Sand Filter
    1HP Super Pump
    250K NG Heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by medic2051
    That must be a huge filter! How big is the pool? Are you sure you're not overcharging the filter?
    I'm not at home now, but I believe it's 60 sq ft. Calls for 9lbs DE. I think the pool is about 24,000 gallons. Sound about right?
    Sand Filter
    1HP Super Pump
    250K NG Heater
    Richard320's Avatar
    Jan 2010
    18,984
    That depends entirely on the size of the filter and what the manufacturer says. It's generally about 1 lb DE for every 10 square feet of filter.
