Results 1 to 7 of 7
Thread: Bob from Iowa
    Apr 2013
    West Des Moines, Iowa
    14
    Bob from Iowa
    Bought a house last December with a pool. Getting ready for our first pool opening. We hope to open between April 29 and May 5. We have a great local business that does a good job supporting pool owners. I just attended my first "pool school" last Saturday which they offer free of charge. They also will be doing our opening with me shadowing.
    There were no owners manual nor specs on what the size of the pool gallon wise nor the equipment. On of my first tasks is to get that all put together.
    Anyway, looking forward to learning more about how to keep the pool sparkling clean and trouble free. Looks like a great site with a lot of interaction and help available.
    25K Gal L-Shape in-ground Vinyl Pool;1 bottom drain - 2 Skimmers, 1.5 HP Pentair pump, Sand Filter, Heater, Liquid Chlorine
    30,432
    Re: Bob from Iowa
    Welcome to the forum.
    Apr 2013
    Austin,TX
    75
    Re: Bob from Iowa
    Thanks glad to be here...........Looks like my new pool is coming along much better now that I've gather info from this web site
    Pool IG, 20'x30'x5', 15,000 gals, QuartzScapes NPT Tahoe Blue, Sundek Classic Texture, DE Hayward Pro-grid DE7220 , Pentair erosion auto CH, Main PMP Century 1.5hp , Polaris 280, booster PMP Century 3/4hp, Electronics PNL timer/light Pro Logic Model AQL2-SS-RF w/Remote CNTL
    Feb 2008
    Denton, TX
    5,061
    Re: Bob from Iowa
    Welcome to TFP!
    Apr 2013
    Austin,TX
    75
    Re: Bob from Iowa
    Thanks Bob,
    I have lots of links (over 40 hours of research on new pool construction ) from plaster to decking to gunite be glad to asnswer any questions you have . My pool is ready for plaster, we're going with Quartzscape tahoe blue. And Sundeck Classic texture for decking finish. I'm at home watching my PB subs and have had issues, which I had to put a stop to and resolve . Various stages of construction have been a nightmare, from a quality control stand point. We're now 10 weeks into the build here in Texas and still not finished.
    Thanks ktc211
    Apr 2013
    14
    Re: Bob from Iowa
    An update.
    Took the pool cover off April 29 to reveal a green swamp. Previous owners let it go. I started with skimming off at least 3 to 4 bushels of floating leaves. Since I couldn't see the bottom, I then proceeded to "scoop" what I could from the bottom of the shallow end. Took out another 2 bushels.
    Had local company come for pool opening on May 2nd in a snow storm no less. They shocked with 32 gals liquid chlorine and added algae and metal additives. Lots of foam and leaves raising to the top. Skimmed another bushels of leaves from the surface and emptied the skimmer baskets several times. The bottom drain seemed plugged with leaves as that line wasn't pulling much water.
    The multi-port valve was leaking. It was replaced. The sand in the filter needed to be replaced. I cleaned out the old sand and replaced with new on the following Sunday and got the filter working.
    With the pump now running, I purchased a leaf vacuum and went over the entire pool taking out another 2 bushels of leaves. Again of of this was blind work since I couldn't see the bottom. I focused on the deep end in an attempt to lift leaves from the bottom drain and free it up. It worked and the bottom drain began flowing water through. Monitored both skimmer baskets and pump basket several times each day and emptied the same. Backwashed the filter when the pump pressure would rise to 10 lbs over normal operating pressure. So far I have backwashed about 6 times on the past 3 weeks.
    We have been trying to keep the FC at least at 10 ppm in order to help clean and clarify. pH has been relatively easy to control. The pool responds to soda ash as expected. Alkalinity and CH were high but seem to be coming down as we get the rest of the things balanced.
    We started seeing the bottom of the shallow end - 3 feet depth - about a week ago. It has steadily improved in terms of clarity but up until we treated for phosphate, it was always cloudy. We also ran into high TDS so I drained about a foot from the pool a week ago, filled back with fresh water and shocked with another 8 gal of liquid chlorine. Helped some with clarity but still not progressing as quickly as we wanted. Turned out we had high phosphate level and I just finished treating for that yesterday. 3 days ago I added the Phosphate Removal, ran the pump for 18 hours, turned the pump off for 24 hours. Yesterday morning woke to a clearer pool with some sediment on the bottom. Still couldn't see the bottom of the deep end but could see farther down - about 6 feet. Vacuumed to waste at the bottom of the deep end by feel until skimmer started sucking air. Drained some more from bottom drain. Refilled pool - about 6 inches and then vacuumed the shallow end to filter. Backwashed filter before, during and after vacuuming. We had a storm blow in so I had to put everything away.
    Woke this morning to a pool where I can see the deep end bottom drain. Not totally crystal clear but I can see the drain. Tests as follows:
    FC - .5
    CC - .5
    pH - 7.5
    Alk - 150
    CH - 380
    Added 4 gals of liquid chlorine (12.5%) at 7:30 am. Will test again at noon to see if we have acceptable FC levels.
    It has been quite a journey. Quite an expensive one at that. Far more than expected. Lesson learned - never put a pool away green.
    Apr 2013
    14
    Re: Bob from Iowa
    Final update for now ...
    Tested pool chems at noon - about 4 hours after adding 4 gals of 12.5% liquid chlorine. Results were ...
    FC - 6.0
    CC - 0
    pH - 7.5
    Pool is nice and clear. I added about 4 oz of SeaLear Natural Clarifier right after I measured the chems. Looks nice and shiny. A few areas with some sediment on the bottom again that I will vacuum up tomorrow. Right now, I am taking a little breather from the pool.
