Thread: Options for a nicheless light
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Is Aqualumin the only niche less light. Since we are having a new liner installed I was gonna replace ours we have a gen 1 and it has some sort of issue every year.
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    buddywiser's Avatar
    Morgantown, WV
    98
    Re: Options for a nicheless light
    I know this is a very old thread, but if you see this, did you get a new light or leave the old one.
    I had my own question about installing a new liner with the same kind of light. Do lights have to be removed to install a new liner? I have the nicheless Aqualumin but I cannot remove the light because I don't know where the junction box is. I have searched and searched, but I'm convinced it is buried in the concrete. The light can be unscrewed and placed on the deck but the cord will still be in the wall. I just wanted to make sure that wouldn't affect a new liner install.
    24000 Gal, 18x36 Vinyl
    Hayward Super Pump
    Jacuzzi Tri Clops Cartridge Filter
    Heat Siphon Heat Pump
