Thread: Hand Rails
    Memphis, TN
    44
    Hand Rails
    Does anyone have any ideas or tips for reinstalling their handrails each season?? Mine are the typical metal hole in the concrete (that's full of dirt, etc) that are old and worn. Each season I can get them in to the holes with some force, but at the end/closing time its almost impossible to get them out. I do not wrench them in with the bolt that's on the side of the hole/insert. So, I'm looking to see if there is a better way before reinserting them for the season. Replacing the hole with a new one isn't an option without tearing up concrete.
    Thanks for any help.
    33000 IG Vinyl, Sand Filter, Circupool SWG, Polaris 180 w/Booster Pump, Mosquito Misting System, Home Automation
    22,551
    Re: Hand Rails
    Could you use a shop vac to vacuum them out and then use a flapper wheel on a drill to polish them before you reinstall the handrails? I'd use something in the 240 grit or finer.
