Thread: Pool Deck problems
    Pool Deck problems
    To start out, pool is only thee years old and had a bad contractor from the start. My issue I need help with now is the concrete deck has low spots and all the rain goes into the pool, we have to pump water out of it in the winter because it over fills, the concrete is even with the top of the pool except the low areas that is causing all the problems, we also already have several hairline cracks, we do have exspanion joints. What I would like to know is what is the best way to fix this without costing a fortune. Is it possible to tile around the perimeter a foot or two as a border, then maybe in the next years finish it. Pool is20 by 48 and the deck is 14 feet on every side. Help and suggestions are appreciated. Thanks
    Oct 2007
    Cedar Hill, TN
    252
    Re: Pool Deck problems
    Would you mind posting a few pictures?
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    30,432
    If the decking is higher than the pool (so the water runs INTO the pool) that will be a very difficult fix. How much higher is it? Some pics would help.
    I will get pictures. It is pouring rain today. The decking is not higher it is just poor elevation slopes in the concrete which has the rain going back into the pool. I am probably not explaining well, i will get pictures so you can see. Thanks
